John100156
Watch out, John - things have changed over the years
Not the case for this little project but in my experience circuit designers now tend to use pic chips and simply wire inputs/outputs. Then internal software sorts out the logic. This makes tracing a curcuit a little more difficult and virtually impossible to copy. Often easier to start again.
So be aware when debugging more modern electronics.
I know Mike, I wish I had more time to play, what with Rasberry-Pi and Arduino, all look like a lot of fun. The problem(s) found on the PCB look like the results of one corroded (sea-water ingress) tactile switch which has also corroded the adjacent tracks, all easily cleaned-up and by-passed so far! One passive component (resistor) looks bad, not burnt-out, but corrosion prevents me reading its colour coding. I could break one end and measure it but then I dont know if it has changed (unlikley, dont really want to break down the other unit!).
New switches are on there way from RS and hopefully Mark will send me his unit! Let's face it, with feedback pots on the motors I could measure voltage or even resistance to find out where the motors are! It would be easy using the pot as a voltage divider to knock-up your own circuit, but you have to stick to original controls of course!
