tjbrace
Encouraged by the responses to Nigel Mercier's recent question I am tempted to pose my question, so here goes:
The power supply to my autopilot has to come from directly from the batteries (not via the distribution board). This I have done, via a 25 amp MCB, as recommended. To retain ON/OFF control at the distribution board, I have a switch to activate an automotive relay in the A/P power line. All works fine, but I am aware that precious amp/hours are wasted maintaining the coil current so I have looked into a latching relay.
Durite have just the beastie, it takes a positive pulse to activate it and another positive pulse to deactivate it. I have found a circuit which uses a relay, resistor, and capacitor to generate a single pulse from a constant 12 volts at switch on time. But I need to generate another pulse when I switch off the 12 volt supply at the distribution board.
Could this be done from a charged capacitor? or some other technique?
Thank you, T
Thank you, T
