Electrolysis
I have recently had to renew my propellor as it was pronounced irrepairable due to electrolysis. There has never been any anode on the boat. I have no room to fit a shaft anode. Has anyone used 1 of the nuts which both secure the prop and have a zinc anode attached. Also if I have to fit a through hull anode how do I bond the shaft to the anode.
Miker
30 Jun 2001
NW England
I had the same problem as you a few years ago. I only had a magnesium prop anode on which did not last more than a month or two then I moved the boat from fresh to sea water. I now know better!
I have an anode on the hub of the prop. I think that these are purpose made for the particular prop and only last three to four months on my boat. As well, I have a shaft anode and a hull anode. The latter is bonded to the shaft by an electro eliminator purchased from Cruisermart. The eliminator is a carbon brush which fits around the shaft. There was a good contact then I last tested but the prop and shaft anodes are the ones that are being eaten through.
I hope this helps and I will be interested in other replies.
jfkal
17 Aug 2001
Singapore
Are you on shore power? If yes make sure you get isolator diodes installed in the grounding line.
Miker
30 Jun 2001
NW England
Re: Shore power and anodes??
My use of shore power is restricted to occasionally charging up the batteries via a Sterling charger. Do I still need diodes to prevent excess erosion of my anodes and, if so, where do I put them?
incognito
N/A
18 Apr 2004
Italy
read http://marinesurvey.com/yacht/corrosion_1.htm for full info. Note that this may not apply to your situation. If you do need to fit a 'galvanic isolator', you should get a proper one, Cactus do one. I fitted one myself, took about an hour, cost over £100, probably quite unnecessary, but nice for feel-good factor.
