Electrocution risk in marinas
Beneteau381
19 Nov 2019
Been thinking a bit and was aware of people saying stray voltage can kill, but how? Surely if you are immersed then how can voltage flow through you?
VicS
13 Jul 2002
The danger is greatest in freshwater, possibly only a serious issue in freshwater. It's because the body is a better conductor than freshwater and the current will take the path of least resistance namely through the body.
Sea water is a better conductor so the current there flows through the water rather than the body.
There is a good, more detailed, explanation in Calder's book
Beneteau381
19 Nov 2019
Will have a read when I get back to the boat, thanks.
mjcoon
18 Jun 2011
Berkshire, UK
www.mjcoon.plus.com
Strictly, of course, it is current that flows, just like water... But you are right, it is that moment with one foot on shore and one foot on the boat that you are vulnerable. But jumping is not advised either!
Momac
7 Feb 2008
UK
I have kept my boat in a freshwater marina since 2008.
The only electric shock issue I have witnessed was not related to the water. The person involved made a cable extension which left the exposed pins of a plug live , which should of course never happen. He unplugged with the other end in the shore power supply and received a shock. He is still alive.
Swimmers in a marina are more likely to be poisoned or cut to sheds by a propeller rather than electrocuted.
pmagowan
7 Sep 2009
Northern Ireland
sites.google.com
I suppose it is one of the considerations of the American style (and modern European Style) of bonding all external fittings such that earth faults can go into the water. I think the risk is small and with RCD and equivalent protection smaller. The risk from pollution in the marina or being run over etc is likely an order of magnitude higher so not swimming in a marina seems like a good idea
V1701
1 Oct 2009
South Coast UK
Well I think swimming is not permitted in most marinas, it isn't in mine. Been here 13 years, sadly a couple of people have fallen in drunk & drowned & one dog died in a boat fire in that time. I do get in to scrub the prop & rudder a couple of times a year though & I fell in once (not drunk but being a bit stupid). Nobody electrocuted at all as far as I'm aware...
Graham376
15 Apr 2018
Don't know the answer but when canals are being drained for maintenance, they use electric wands to stun the fish so they can be netted. Wonder how many volts it would take to stun orcas?
Gsailor
30 Sep 2022
I would hope ( and thought ) that mcbs reacted so quickly that a shock was not lethal.
Have I been deluded ? (is that the right word? - losing my faculties I fear)
mjcoon
18 Jun 2011
Berkshire, UK
www.mjcoon.plus.com
I thought that was the intent. And I think the time cited on my portable RCD is ~1 cycle of 50Hz, which is about as fast as one could expect...
VicS
13 Jul 2002
Not the mcb ( that's an overcurrent protection device ) An rcd ( or rcbo) should trip if leakage into the water occurs even before any swimmer is involved.
There is more information in Calder's book under the "Ground Fault Circuit Breakers and Residual Current Devices" heading
Trident
21 Sep 2012
Somewhere, nowhere
I remember that someone was killed at a marina in North Cyprus, Karpaz Gate, when it first went in to operation because of faulty wiring that put the current through the metal cover strip down the side of the pontoon!
Also some US states ban external (to water) earthing of the boat due to the risk to swimmers even though it is very minimal.
oldmanofthehills
13 Aug 2010
Bristol / Cornwall
If they are fitted. Certainly i would not trust greek or turkish wiring and I have seen plenty of rubbish french and english wiring in buildings (builder with electrically qualified son)
