All_at_Sea
Currently I have one breaker in the incoming 240v supply shorepower line. I am just about to add a generator to this so thought l would upgrade the 240v system. My plan is to put in a garage consumer unit, 6 way. So far so good. However I note that most marinas run on a 16amp supply, so is there any need for any MCB to be any bigger than this? Most boxes I see have a domestic 63A incomer, but l was going to reduce this to either 30 or even 16 amp supply.
The genny will be a 4kw unit.
Having done that I was going to have the interior circuits as, sockets 16amp, immersion 6amp, batt charger 10amp. Does this seem ok or do you use a different regime?
