BobA
I know that it may seem obvious to some of you guys who have had a boat for a long time, but, to me, just starting out on the "Great Expense of boat ownership" I am unsure of how I can charge my batteries.
Explanation --- I have a starter battery ( I think it is 75amphrs) there isn't a lable on it) and I also have two 110amphrs for domestics.
At the moment I am removing the batteries to charge them individually but this does cause a bit of a problem when SHMBO has to sit waiting for me to set them up again before we can get out on the water not to mention the hassle of lugging them about - hence my previous post on shorepower.
This is all set up now but I am still unsure of how to charge all the batteries.
I was planning on connecting the battery charger to the domestic bank and leaving the 1-2-both switch in the BOTH position to allow the charger to charge both banks simultaneously.
Question 1 - would this work?
Question 2 - will it cause any problems with me leaving the boat"on charge" for up to 10 days at a time? - I often have to work away from home and cannot get to the boat.
I am using a Halfords Leisure charger which according to the "blurb" is ok to leave on for extended periods. But it does say that if you are unable to remove the batteries then you should disconnect the negative terminal. I would think that that would then stop the charging of the other two batteries and defeat the object.
Your suggestions would be appreciated.
Bob
Bob
