Electrical help required (again) please.
chasroberts
27 Feb 2004
Cap d'Agde, France
I am redoing some inherited wiring on our fridge and am in a bit of a quandry. Whoever wired this up originally has proceeded as follows:
12V positive direct to the fridge unit from one of the two house batteries through a fuse holder.
12V negative direct from battery to fridge unit through fridge on/off switch.
This obviously means that the positive power to the fridge is permanently on even when the battery switches and the fridge switch are off which I seem to remember is not considered 'good form'.
Is there any reason why the negative side would be switched instead of the positive?
I am considering taking a new positive lead from the battery 1 terminal on the main battery switch through a suitable fuse to the switch and from there to the fridge and leaving the negative from the battery direct which is close by the fridge but obviously removing it from the switch.
Can anybody give me any ideas as to whether this is the accepted method or is there another more elegant idea that might make life simpler and easier.
As always, my thanks in advance to all the panel.
Chas
If the switch is on the positive (normal) then the negative doesn't need to go back to the battery but just to ground somewhere convenient. The battery may of course be convenient if the wiring is already there.
As long as you break the circuit then the fridge will switch off, but normal practice as you say is to switch the positive side and common the negative sides of all devices to the battery. This is because if you only switch the negative side then if there's a fault there is the potential (sorry) for current to flow through the unswitched positive and out the negative of another appliance when both are switched off. Your plan sounds good, and if you are really paranoid you could switch both positive and negative, and completely isolate the device.
Possibly the previous owner thought of isolating everything except the fridge. i.e. leave the boat for a few hrs in the pub but need the fridge to stay cool.
It's a bad idea IMO. In an emergency you want to isolate everything with one switch immediately. Alternatively, you flip the isolator but forget thr fridge. Next time you're on the boat the domestic bank is flat. You can always charge it but it's not a good idea to flatten it completely.
[/ QUOTE ] Still does not explain the switch being in the negative .........unless the main battery isolator is in the negative.
There is nothing at all wrong with the arrangement you describe; except that it is little unorthodox (which could create a problem if someone modifies it without understanding it)
