Electrical Diagrams tips
christopherr
31 May 2007
Spain
www.lat39.com
If you want to save money on repairs in your yacht make shure that any electrician that decides to install or modify your electical system alway makes a electrical drawing diagram to add to your files to be able to pass the info to the next users . If the electrician is not able to do it ...get another one ..you will save pleanty of money by not having to spend time to trace loose cables .
sarabande
6 May 2005
Jolly good idea, Christopherr. Can we develop it a bit more please ?
Given that the "as-installed" wiring is in three dimensions, what's the best method of showing this on a 2D piece of paper ?
What are your views on colour-coding of the wiring to identify different circuits ?
Are there any internationally recognised symbols for electrical equipment and wiring which you suggest can be obtained and used ?
If you are going to use a programme, what would you recommend ?
thanks
