Ammonite
As part of some recent continuity testing I thought I would double check my meter by testing something that I thought should definitely be isolated, which happened to be the two jubilee clips holding on the rubber end cap of my MD2040 heat exchanger. There is no metal to metal contact at any point as far as I can ascertain and the cap is clean and dry (the clips are not touching anything other than rubber) Having read that conductive and non conductive rubber hose is a thing is it possible the end cap falls into the conductive category? I've removed the clips and checked that neither have pierced the rubber cap but each time I do up the clips I have conductivity. My assumption was that they both must be touching something metallic but I can't find where they are. The meter is working correctly in other tests.
