electrical connections - silicon grease - use or not?
PaulR
9 Sep 2001
Home West Sussex, Boat on Mooring in Gosport
have slight voltage drop on the earth wiring on our boat so at the weekend took off the connections to the alternator and cleaned all the connections - liberally coated them with silicon grease and reassembled - voltage drop now worse!
suspect the grease (that I had understood is good for electrical connections) is the problem - hence 2 questions.
1. Anyone suggest best way of cleaning off the silicon grease from connections?
2. I take it correct approach is to clean the contacts - do up the connections (without silicone grease or anything else) and then - apply grease to the external faces of the contacts- is that best way or should I be using anything else in the contacts ?
thanks
The increase in voltage drop sounds likely to be a badly-made crimp connection on one of your wiring terminal fittings.
As you say, assemble everything, then a small smear of grease to help keep salt spray, water vapour etc out and reduce the opportunity for corrosion.
