Electrical connections exposed to salt spray.
TQA
20 Feb 2005
Carribbean currently Grenada
sailingonelephantschild.blogspot.com
My bow lights are mounted on plates on the pushpit and are connected to wires that emerge from the pushpit tube. The PO used a crimp and covered the joints with self amalgamating tape. It lasted a few years but has corroded away.
I could repeat the crimp but would soldering the wires be any better?
I think dipping the connector in liquid electrical tape has got to be better than self amalgamating tape.
Any other suggestions?
lpdsn
3 Apr 2009
Crimp connectors with heatshrink.
prv
29 Nov 2009
Southampton
I would solder and then cover with correctly-sized adhesive-lined heatshrink. Inspect the ends of the heatshrink once cooled to ensure there is a continuous bead of glue squeezed out all round the wire. If so, this should be impervious for many years to come (eventual failure by UV breakdown of the plastic, I guess).
simonfraser
13 Mar 2004
All of the above is likely to work well, keep the moisture / movement out.
Good write up in the PBO recently.
Even choc connectors did ok, if wrapped sufficiently.
KevinT1
23 Nov 2011
Home Noss Mayo, Boat Yealm
On our HR there are no external connections - the wires are terminated in the front cabin having run down the inside of the pulpit tube and then through a deck fitting and through the anchor locker.
That means I disconnect the cables if I need to remove the Pulpit, but it also means I don't have any connections exposed to seawater.
Cover the connections inside the light units with Contralube 770 and use tinned wire should prevenet any other corrosion.
Kevin
johnalison
14 Feb 2007
Essex
Loose ends can be covered with various things. I have used setting silicone or Bluetak successfully at various times when I was too lazy to get anything better. Bluetak is good for bare aerial plugs too but obviously, not for nav lights.
