Abestea
Hi,
I have been attempting to learn a little bit about the wiring within my Sigma 33 so i can wire up a new mast head light and a depth gauge. When i examined the current state, there are fuses attached to both the +ve and -ve wires. I am more used to car elecrics which only have one fuse. Is this normal in boats?
Plus my researching has determined that all books talk about having a bus bar. On the boat the +ve fusebox and -ve fuse box has wires connecting the separate fuses together. In almost a rudimentary +ve and -ve busbar attached directly. Is this ok to have or should i install two separate busbars and have connecting wires.
I am thinking this may be a better option as i may want to add further electrical equipment and the busbars would be more sensible.
Oh and why do my port lights have two +ve and two -ve wires foing to each light where the starboard side lights have only one +ve and one -ve wire going to each light? Is this a starboard/port parallel circuit and the lights on each side are in series?
When it comes to electricity i am not a bright spark!
thanks
thanks
