Neeves
I believe that there are still people sailing around in small boats.
But they will not be looking at the Cayman, which is for 8mm/10mm chain, but a smaller model in the first place
Another +1. Makes no sense to underspecify. The 1000W version of the Cayman for example is physically the same as the 700W and only £30 more in money. Similar with other models.
The whole point of fitting an electric windlass is to make life easier in all conditions.
I agree with this, (and have a 1000W one myself) but I thought your original statement was a bit too strongly worded. By all means advise the OP that once one has gone electric and is buying new then one might as well go for the bigger model, but supposing he found an 800W one it would still be transformative compared to life without!
fit a wired handset as a backup but the wireless remote just makes things simple. It also makes dropping or recovering the anchor easy when single handing, as you can control the windlass from where else you need to be on the boat.
I sail single handed a lot and don’t have problems lowering or lifting the anchor. One problem of not being next to the windlass, in the cockpit, is that when lifting the anchor you won’t see any snagging or debris on the chain. Chain goes into locker it builds up and unless the pile is cleared you have a problem. There are more benefits to being at the bow roller end of the boat when anchoring.
Another consideration would be to have a quick release free spool on the gypsy, but you cannot do this remotely. Very quick to deploy and no power required.
We also use foot switches. These have proved to be reliable and we use them 95% of the time. We have a cheap wireless remote that I use to lift the rib each night using the windlass rope drum. This allows me to be next to the rib rather than by the windlassWe operate our windlass with foot switches which have been pretty trouble free. I do need to stretch to retrieve, with my foot, and look at the actual retrieval below the bow roller. The number of people who have remote control of the winch and their low cost suggest they work and they merit purchase. There is a rather wide choice of remotes on eBay - are there any recommendations or any to steer clear of?
Jonathan
Ok, so although it has taken a little time, I am now ready to run the cabling for a lofrans Cayman windlass. The question I have is does it matter where the solenoid is situated? I have an ideal spot for the breaker near the battery at the stern, but should the solenoid be nearer the windlass, or could it be next to the breaker
On the Cayman there is am neg and a plus that goes all the way to the solenoid then three cables coming from the windlass to the solenoid as Paul saidUnless you have a reversing windlass, there will be one heavy +ve cable from the battery to the solenoid and 2+ve cables from the solenoid to the windlass. Putting the solenoid near the windlass reduces the amount of cable you have to buy.
On my Lofrans the heavy neg cable goes direct to the windlass, with a light neg cable being used to operate the solenoid - one less join in the heavy neg cable. Irrespective the end result is the same in terms of heavy cable lengths which ever way it is wired.
