eddystone
Prior to launching a newly acquired 32' boat I had an electric windlass professionally fitted. Due to circumstances the whole installation was specced and fitted by the shipwright ("please fit me an appropriate electric windlass" as opposed to "I have acquired all these parts please fit them for me" {"you know this will all work do you because its your choice and it's not my responsibility if it doesn't"}) - . The installation is neat enough and well executed but I suspect the boat is at the very top end of the size range for that windlass. As it happened I used it for the first time this weekend and had a couple of issues which, due to lack of experience with these things, cannot judge whether shortcomings in the installation or just inherent problems with electric windlasses. Actually, not so bothered about windlass power because after all the idea is to lift it not drag it out; because I hadn't marked the chain I unnecessarily let out the whole 30 metres and when I tried to pull it back in, the chain/anchorplait splice, which went out OK, jammed on the windlass and also wouldn't go through the hawse pipe; in the end managed to lift the splice off the windlass and drag it back through the hawse pipe by pulling from the chain locker side. Secondly, when lifting the chain when most of it was lifted it tended to jam because the chain was piling up in the locker preventing it from dropping (the locker is quite shallow)
My instinct is that given the shallow chain locker, the second issue is unavoidable, i.e. there is no way of getting a better drop, but the problem of the chain/rope splice could have been foreseen. Am I mistaken? The only obvious solution (other than not anchoring where I need more than 30 metres and manually dragging the splice back down through the hawse pipe when I do) is to add maybe another 10 metres of chain to replace the rope and keep an anchor warp separate to shackle on when needed.
Irony is I probably wouldn't have discovered these issues had I done what I should have done and marked distances on the chain with paint!
