capnsensible
I used a Winchrite
I like the look of that. Think its gonna go on my shopping list!
I used a Winchrite
If you are going to get it very salty then it won’t end well. A protective coating like AC50 or Boeshield would be a good idea I think.The Winchrite isn’t waterproof by the way, just water resistant.Im more interested in the Winchrite as its designed for afloat use. Ive endexed a drill before with seawater. Open mind though.
A home made extra long winch handle might be all that is needed if it’s only the last bit of trimming that you find hard. You can buy slightly longer winch handles. Maybe you need to try them first if you haven’t already. Then again if it’s not a problem of strength, but stamina a drill will help.
Its not really a strngth issue so much as an "out of puff" issue. The boat is 35ft, the genoa is 140% and the winches are 44s. Not that difficult to raise the main - more an issue of winding in the genoa if single handing. My pilot ( below deck hydraulic) is good but not sensitive enough to hold the boat just luffing the headsail to lighten the load.
Not at all sure about having a heavy old lump of an electric drill in the cockpit all the time. And swapping from side to side.
Also not why halve the cost by fitting only one electric winch as opposed to two? If you don't need room to hand wind it, it could perhaps be placed centrally somewhere like an old fashioned capstan, thereby covering all winching requirements?
Maybe even put up with the reduced performance of a club footed self-tacker for short tacking?
