Electric Water Heater
The question is, do I want stainless or Incoloy element?
Id guess it depends on the analysis of the water where it is going to be used.
Presumably you are not fixed and move about a fair bit so you may encounter a wide variation in water supply composition.
It could therefore be wise to choose the Incoloy option.
So, I have the length (30cm), the thread (1¼" BSPP) and the wattage (800W) ... Incoloy element
I can't believe that I've drawn a blank with this specification.
Element length: approx 30cm
Element material: Incoloy (or Stainless)
Thread: 1¼" BSPP
Wattage: approx 800W @ 230V
Thermostat: 230V
Any suggestions where I can get these items?
Thread: 1¼" BSPP
Thermostat: 230V
I too have a similar problem - I've given up on trying to replace the element - I'm sure, if you could find an Italian forum to post on you'd get an answer.
