UMCorps
Going through the thread I see no one has commented on the durability or issues of use in Salt water? Any info appreciated.
Sailfish156
I have no issues in salt water with my Torqeedo. Being lazy, I only rinse it properly at the end of the season. It doesn't seem to do it any harm.
I don't need to remove the battery for storage so that stays connected for the season as well. I find that the tiller cable connection needs to be connected with care and kept very clean if it is to be reliable. It's very quick to throw an E32 error if it doesn't like the quality of the connection. I give it an occasional spray of contact cleaner and/or WD40 which helps. A light smear of silicon grease on the thread of the connection nut is also useful.
On mine, (which is 2nd hand and at least 5 years old now) the centre indent on the twist grip is rather vague. Sometimes the grip will feel like its sat in the centre indent but the prop continues to turn slowly. On other occasions, when twisting the grip to start (in either direction) nothing happens. It's as if the motor doesn't recognise that the pot has left the centre indent. It needs a bit of a waggle to kick it into life. I suspect it will need replacing at some stage soon.
Minor issues really. Certainly a lot more reliable and a lot less hassle than a petrol outboard.
