nimuemusic
Any views on electric outboards for use with an inflatable. Are they worth considering? If so what thrust and which makes are reliable?
That was what electric outboards were developed for getting on for 35 years ago. Popular pastime in US is bass fishing on lakes which are often drowned valleys. Deep water in the centre and shallow at the edges with lots of underwater obstructions. Roar across the lake on your flat bottomed skiff. Shut the engine, lift it, then nose around the shallows with your trolling motor up front. Comfortable chair to sit on, 6 pack of Bud in the ice box - what else could one want?
I have used a Minn Kota Endura Pro 32 on a 2.6 meter inflatable on inland waterways and it gives a speed of about 3 knots. I think that it would struggle on more exposed water with both wind and waves.
The weight of the battery can be a problem if you need to use the dinghy as a tender.
The cheaper motors are not suitable for salt water. Minn Kota have a range of motors for salt water but they are significantly more expensive than the equivalent freshwater models.
Has a torqueedo for a couple of years, thrust was ok to push 8" redcrest style dinghy along in tidal waters, battery life was pretty good. In the end sold it with the boat as every 10th trip or so the battery lights would all flash meaning there was a fault and the battery had to be returned to the factory. In the end went back to 2 stroke. At least when an outboard stops you can mess with it.
