dulls
N/A
What about range. We used to have either the 503 or 1003 and i was trying to remember the ranges. We will not go back to petrol. Good and informative post.Just used our Torqeedo 1103 for the first time up the River Dart. Observations: Very light to manipulate around once broken into its three sections. The shaft is still awkward to get onto the dinghy and vice versa but I guess there is no getting away from this (same as on a petrol engine although Torqedo is a lot lighter at 10.3 kgs). Battery life very dependent on speed ranging from 50 minutes to 6 hours but the display allows you to regulate/manage this very easily. At the 6 hour hour endurance, we still managed 2.7 kts which on a ship to shore excursion of only a few hundred metres is fine. Razzing around (?) at a heady 5.5 kts also worked fine as we were able to recharge overnight. Point being that with a little aforethought, you can manage speed and range according to where you are etc. You could always get away with a smaller (cheaper) battery if flexibility in charging Vs. usage is not an issue. Odd to hear the water chuckling under the dinghy rather than this being drowned out by the sound of the petrol engine. My wife thought the engine had packed up it was so quiet. The new transmission on latest 1103 largely does away with any discernible noise . The joy of not having smelly and greasy petrol aboard either in cans or integral tank was great. We have stowed the shaft away in a space that would not have taken a petrol outboard so no outboard hanging on a rail now which is less unsightly and more secure from scrote activity.....Certainly they are expensive but all electric propulsion is expensive, so you pays your money and takes your choice. At the end of the day though, IMO this system works and works well as an alternative to petrol.
Finally, I spent some time agonising about whether to go for the 1003 with the bigger battery or the 1103 (which only comes with the bigger battery). At the end of the day, there was not a lot of difference in price between these two very expensive engines . I went for the 1103 simply because the gearbox had been uprated from the 1003 and hopefully that would "future proof" it for a little longer than the 1003. That may not be the case in reality but ever the optimist....
