Electric Lavac
pessimist
7 May 2003
Exmoor. Boat in Dartmuff.
We need to replace one of the on board toilets and are considering going electric. We'll stick with Lavac because:
a) We like them
b) All the plumbing is new so no need to replace.
We're wondering if anyone has experience of the electric version and whether it's worth the extra cash. I assume that there is still a manual pump and the electric works in series with it?
Any info welcome.
a) We like them
Any info welcome.
I have a Lavac that has a jabsco diaphragm pump
https://www.jabscoshop.com/marine/p...f-priming-diaphragm-waste-pump-12-volt-dc.htm
But I fitted mine in parallel as I found that the outlet valve ( tri lobe) on the manual pump could be stuck closed due to the suction or the electric as mine was fitted on the outlet of the manual pump. I could not fit so the pump was between the head and the manual pump.
I also have the Whale type
http://www.whalepumps.com/marine/pr...D=10027&FriendlyID=Electric-Black-Waste-pumps
Which I think is better as it has double non return valves so a less likely to jam open thus stopping pumping.
a) We like them
Any info welcome.
Depends how you choose to do it. You can have the two pumps in series, or parallel, or just the electric pump.
I recently priced on for a customer and found it better value to buy a manual toilet and add a Jabsco electric pump. Frinstance https://www.marinesuperstore.com/toilets/toilets/blakes-lavac-toilet (better prices may be available).
