haulyfryn
I am in the process of buying a Dufour Countess 32 and have noticed that the electric head is letting water back into the bowl after flushing. The electric pump sounds normal and empties the bowl quickly, but water then enters the bowl again to just under half full. Is it possible for water to run back through the electric pump or should the inlet/outlet sea cocks be closed after every use?
One other thing is that the selection valve for the waste tank is seized and I am not sure if some of the water is going into the tank and then back into the bowl. Is this possible?
