Electric Cable - Anti corrosion solutions?
viva
2 Nov 2009
The positive cable that connects to the battery terminal is 6mm dia multi-strand copper. It is connected to the terminal post connector by two screws which tighten down onto the cable. The problem is that, despite coating the terminal post connector with Vaseline, the cable end corrodes after a few months and causes starting problems. I have thought about tinning the cable end, but I fear it will be too much of a heat sink and will be difficult to achieve with a soldering iron. I don’t fancy using a blow lamp in the confined space and might melt the insulation. I have thought about crimping a non corrosive sleeve to the cable, but this may make the cable too thick for connection to the terminal.
So my questions are
1. Is there a tried and tested paste or gel that prevents corrosion but allows good conductivity in a marine environment?
2. Is there a way of tinning or applying a thin sleeve?
I agree the battery terminal should be changed to the type that greenalien linked to. Bare wire cannot be kept corrosion free in a boat for long. Even if tinned the cut end isn't. The proper way is a crimped on tinned copper lug. If you don't have crimpers able to do this I am sure an electrical shop or chandlery can do it for you for very little coin. With adhesive heatshrink over it there will not be any corrosion.
