dylanwinter
On the way back from Inverness yesterday I called into South Ferriby to look at an elderly Centaur
built `1973
newish 2007 Yanmar engine
it has the usual gelcoat cracks, idiosyncratic electrics and saggy headlining
few snaps here
http://www.keepturningleft.co.uk/sa...arkoula-elderly-centaur-with-a-newish-engine/
it is an old one and has the inner shrouds attached above the window
but it also appears to have the U bolts for the later toe rail anchor point
http://www.keepturningleft.co.uk/wp-content/uploads/Sequence-0321.jpg
there is some sort of crack by the edge of the window
http://www.keepturningleft.co.uk/wp-content/uploads/Sequence-03008.jpg
this has had a gobbit of really badly applied gunge on it
the old survey said
"A crack was noted in the GRP above the f orward port saloon window. This was reportedly there when the
current owner purchased the vessel. The repair is cosmetically poor and thought should be given to the
areas being professionally repaired."
any thoughts chaps?
D
built `1973
few snaps here
any thoughts chaps?
D
