MapisM
You sure did, congratulations!Hopefully mastered it!
Btw, I see that you used the website I mentioned, i.e. imgbox, whose pros and cons I'm by now familiar with.
And one of its (very minor, in fairness) cons is that the links it generates automatically are a bit weird, because they include the "URL" tag, whose only purpose is to make the image a clickbait.
In practice, for the above image you used the following sentence:
Which is 100% correct, and shows the following image as a result.
Otoh, if you would have copied the automatic link generated by the imgbox website, the sentence would have been as follows:
[urI=http://imgbox.com/udMSZWJ6]
Note that the central part included in the "IMG" tags is exactly the same as above, and is the one that actually does the job.
The rest (which I grayed out) is what makes the image itself an hyperlink: the result looks the same, but if you click on the previous image nothing happens, while the one below redirects you to imgbox website.
...with apologies if this is just a complicated way to confirm that you already did the perfectly right thing, but just in case you should wonder why imgbox automatically suggests something different! :encouragement:
