vas
evening all,
another question that easily fits on the subject line
So managed to fit my stbrd engine custom NMEA2000 box that does a few measurements and dumps them in the N2K bus only to find that EGT is 80-90C on idle, is that okay or too low?
EGT probe is around 200mm after the turbo outlet flange on the "hot" gasses only part of the elbow as it goes up before turning back down and mix with the seawater.
I'm stuck in port, port engine heat exchangers about to be taken out for cleaning, so no way of doing a proper test.
Value is digitally calculated with the MAX31855 board integrated in my box, so not an issue of accuracy of the value reported, mainly wanting to compare with what others see. No doubt that will go up to over 200C once moving, just want to confirm that others see 100C only after revs go up to 1000 or so on idle.
cheers
V.
cheers
V.
