scr0che
I've started to get an eggy smell from the heads tap, and the galley foot pump outlet only - not from the galley tap. So the smell isn't everywhere. Never had this before in 8 years, but have always put a chlorine tablet in when filling up. I'm now using a watermaker. The heads and galley are now used every day as we're live aboard.
I had a broken sender in the water tank under the cabin sole letting air in which is now fixed. The pipework is over 8 years old from when I bought the boat.
Should I look at replacing pipes? I'm reading about flushing with a bleach solution to kill bacteria in pipes, but I have a watermaker and don't want the flush cycle which uses tank water to damage the membrane.
Is there an off the shelf product I can put in the water system to flush it through?
