daveyjones
I'd like to make some large cleats and other bits of deck "furniture" in oak ( for strength), but as I will be using galvanised mild-steel bolts to attach them to the hull, I'm worried about the effect the acids in the wood will have on the bolts. Is this a rapid process, or does it take years to corrode the bolt, and is it possible to protect the metal by painting in Hammerite or tar, or anything else? Could you wrap the bolt in something, say insulation tape, to prevent direct contact with the wood? Is there a suitable alternative timber, not too expensive but strong? I used Iroko on my last boat, but here in Kent there is a local source of local oak, which is very cheap. Thanks.
