rogerroger
Running aground twice on Saturday confirmed the fact that I need to do something with the echo sounder over the winter.
It's a NASA Target with an in-hull mounted kit. The problems are
1. oil drains out of the in-hull kit so it stops working - OK, so I can seal this better
2. It's to port of the keel so stops reading when heeled a fair bit to starboard.
3. It does not read anything below 1 meter - this is a nonsense as there's a huge difference between 10 cm and 90 cm when working in shallows.
Should I ...
Chuck everything out and start again ?
Sort out the in-hull kit and add a new display - if so, can I add a different make unit onto the existing coax ?
Are there advantages to a through-hull unit and is this a big job ? (don't like the sound of another hole in the hull!)
Many thanks
Roger Holden
www.first-magnitude.co.uk
Should I ...
Many thanks
Roger Holden
