Danny
I recently had intermittent problems with my Nasa echo sounder and couldn't decide if it was the transducer or the head causing it. I took both into Nasa who sorted the problem out for me. Their premises seem a bit on the scruffy side but their service was excellent and they're very friendly. Anyway, I picked up some tips from the resident guru which might be of help to someone sometime...
1/ If the head's transmitting you should be able to hear the transducer clicking.
2/ To see if the receiver's working rub the palm of your hand over the face of the transducer. You should get random readings on the display.
3/ To check the accuracy you can use a 1 metre length of plastic drainpipe of around the diameter of the transducer, or more. Poke the transducer in one end and hold the palm of your hand over the other end. You should get a reading of 4.5 metres.
All this works for Nasa Cipper E/S and I imagine will work for other E/S's as well.
