SHUG
Yup, the correspondence confirms my experience. When they are good they are very good but when they are bad they are *^%$£%**£$@~#]{+*****...diabolical!
J
so I think Little Sister made a rather sweeping statement about the loadings of the Eber units IMHO
In any case, as someone has said, they need more 12 volt power than you're likely to have available with an outboard.
A myth that just isn't true. I have had an Eber and an outboard engine combination for over a decade - and a CF18 compressor coolbox as well. No flat batteries yet.
It's not a myth that most small outboards won't have enough charging power to keep up with a significant load (i.e. used over many hours) from the occasional mainly short term use of the engine that would be typical in a sailing boat with an outboard auxiliary. Hence it seems from your other post you have to run your engine all the time you have your heater on, which most wouldn't consider a satisfactory arrangement (though I'm pleased it works for you).
I've said it before, but I'll say it again: Ebers get a bad press because people buy old knackered second hand ones cheaply, install them poorly and then complain when they break down. The only time ours has stopped was when a printed circuit board failed. I can't be too harsh on Eber as electronics occasionally fail in many applications. Apart from that it only ever stops when it runs out of fuel!
As others have said, there are hundreds if thousands around and therefore the failures get reported more.
+1
But it is a myth that there are more of them than others, just that you in the small world of boating see more on boats. If you were NATO you would see more Webastos,again, because they are installed and serviced correctly there are few issues.
Personally .... I am not a fan of blown air
And removed an Eber D4 and fitted a drip feed. Which is a bit like saying I luv marmite
But, 3 winters aboard with the snow damp etc ,, one happy dry bunny
but it's the same output and size as an Eber,
I suggest you look at the numbers again, they are not even close in real specs, which are BTU and air volume output, the KW is pretty meaningless. a 2kw Heatsource is a country mile from a 2kw Ebrer, Webasto or Mikuni where it matters, OK if price is your overriding parameter.
The Eber D2 that came with our boat has been a massive PITA. However, this was due to a diabolical install. Truly, truly diabolical. I've ended up servicing it, sorting out the location, wiring and fuel uptake and so far it has worked great. Well, apart from now, but that's because our fuel tank is below 1/4 full and the fuel pickup doesn't reach.![]()
Why is BTU different from KW? (apart from conversion factor)?
