Pinnacle
Our heater is located under the swim platform. Getting to it is a real pain, but its location also means that the exhaust has to run up through a deep cockpit locker on its way to the skin fitting high up on the transom. We have had a couple of instances where fenders stored in the locker have been ruined by being melted when leaning against the exhaust. The standard stainless exhauset pipe is covered in white lagging and is run inside a 50mm dia section of the normal black air ducting. However, as noted above, the outside of the black duct still gets too hot for the fenders.
So, in an effort to overcome this, I purchased ( at not inconsiderable expense ) some sections of the MaxiTherm duct insulation made by Eberspacher. It was easy to fit as its simply wrapped around the duct and then held in place with stainless pop fasteners. Job done in about 15 mins. All well, so I thought...........
About 10 mins later, No 2 son asked what was burning. A quick inspection showed that the insulation was being melted!.
Turned off the heater and let it cool. I have removed as much as I can of the remains of the insulation, but quite a bit is still left stuck to the black duct. Next time we use the heater, it will, of course, melt further and stink the boat out ( or maybe set itself on fire? ).
So, my simple plan looks like it will cost me ££ss to have the whole exhaust replaced. ( I think it makes sense to replace the stainless pipe and its lagging at the same time as the engineer has it all in bits and is replacing the duct. )
I feel such an idiot.
Boats.....don'tcha just love 'em!
