Eberspacher fuel tank position?
MINESAPINT2
23 Nov 2007
Not sure how the red diesel thing will pan out eventually but assuming we have to use white for propulsion I could really do with a second tank for my eberspacher so I can use red. Currently engine and Eber run off same tank. The existing tank is just below the level of the Eber and I am wondering if I fitted a new tank 4 feet below the Eber would the pump be able to supply fuel.
Mike
This picture came from the truck installation instructions for a D2 . The same picture is not in my marine installation instructions.View attachment 92665
Www.solocoastalsailing.co.uk
Thanks,
My installation manual has a similar diagram which indicates maximum head to the pump from the bottom of the fuel tank 750mm (same as above) but my diagram does not indicate maximum head from the pump to the Eberspacher. It just indicates maximum pipe run of 6 metres.
Not yet decided whether to fit an additional tank or just use white diesel in the Eberspacher. Will make a decision when HMRC makes everything clear.
Mike
I think the suction head is the most critical as the pump needs to prime itself, after the pump is mostly about pipe size and friction to effect flow rate in simple terms.
