3663Ian
Active Member
The attached photo shows the exhaust pipe for an Eberspacher D3L heater. I have removed it because it had developed a small leak which was allowing some fumes to enter the stern locker where the heater is mounted. I have removed the lagging, pressure tested the pipe in a bath of water and found a small hole in the flexible section of the pipe. I plan to replace it with a new one. The pipe is 1 meter long . The heater end has and ID of 24mm and the skin fitting end has an ID of 29.5mm (may be it's 30mm as it still has some sealant in it!). The end fittings appear to be braised to the flexible pipe. Can I buy a part like this pre-assembled or will I need to get someone to make one up for me. I can see plenty of 24mm pipe available will that attach directly to the heater with a appropriate clamp or does it need an end fitting?
Ian
Ian
