Chris7576
New Member
Yes, sorry, 240 ticks per minute. It keeps working like this till the thermostat temperature is reached, then the heater stops . After a while, when the temperature decreases below the thermostat settings the heater starts again. I did not use the heater for a long time and I'm not sure, but I thought the pump rate would decrease a lot after some minutes. May be I'm wrong, may be 240 ticks per minute is the normal rate ?Per second, surely per minute? It will continue ticking fast until it drops down to the next heat level which depends on boat temperature so time will vary. Are you saying it doesn't slow down even after extended period?
