Eberspacher D3L diesel heater wiring diagram needed!
nuttynick
24 Aug 2013
Kent
Help, my dad is rebuilding a Bates Starcraft that has one of these fitted. When I say fitted, the previous owner sat it loosely behind a panel with half the connections done! I need a wiring diagram to finish a proper instal, but can't find one anywhere. I've done a search on here and on their website with no joy?
Thanks,
Nick
nuttynick
24 Aug 2013
Kent
I've still had no luck sourcing a wiring diagram, so here's a picture showing where I am. The rotary dial is the new switch, however, the plug wasn't connected and the wiring colours don't follow exactly. Any ideas? Thanks
Pasarell
18 Jan 2007
Greece
I have a D3L with associated installation and operation instructions on my boat. My thermostat is the one at bottom of page 2 in the details L'escargot sent you with the switch to the right above the thermostat picture. I imagine you will get all the information you need from these details but if not let me know. I won't be back at the boat until November so plenty of time to try things out!
PCUK
29 Jun 2005
Westleigh, Nr Tiverton, Devon.
Be aware that vehicle wiring uses different colours to marine and you will need the make of vehicle get the right colours as each maker uses their own colours to correspond to their vehicle loom.
nuttynick
24 Aug 2013
Kent
Thanks for all the replies, by the look of it my switch is the one on the right, No 8. It has a click anti-clockwise to vent, then heat is clockwise. All the parts are Eberspacher, it's just a case of getting it to work!
