Cardo
Fairly sure that's not the case. I stopped getting the low voltage shutoff error after I beefed up the cables. It was also refusing to start with the mains charger on bulk charge, which generally puts out a higher voltage than the alternator at relatively low revs.OR, you've still got a voltage problem.
I would suggest you bite the bullet and install the Eber recommended standpipe directly into the tank. It will be worth the effort in the long run.
I have installed 2 Ebers this way. The first worked without a single failure in 13 years (before I sold the boat) and the second (recently fitted) worked first time (after initial priming) and continues to work with any problems.
I must say, whilst I'd love to do this, it just sounds like it's pretty tricky to do. I'm guessing I'd have to completely empty out the tank (grief!) and then find someone with the right tool to cut the hole, before fitting the standpipe.
That or keep tank full or start the engine to start the Eber...
