asj1
To avoid trailing wires and extension leads tomorrow I intend to fit shore power to my Fulmar. This will be relatively simple with a "consumer unit" with RCD and MCB's and two sockets one of which will be dedicated to the battery charger and one of which will be for a single socket to be used as required. I am happy with the wiring and everything I have bought.
My query is the wiring for the earth. I have read that this must be wired into the 12v negative, but I have also been told to wire the 240v earth to the earthing point on the engine block.
Questions:
1) where should I wire the earth to, the block or the negative side of one of the batteries
2) from where in my 240v circuit should I take this wire to the earth, does it matter? It would be shortest and tehrefore easiest to take it from teh earthing point on on the socket being used for the battery charger.
I am not going to fit a Galvanic isolater as I don't intend to leave shore power permanently connected.
Regards
Questions:
Regards
