nigelmercier
RIP
- Joined
- 20 Jun 2007
- Messages
- 16,234
- Location
- Live in Kent, boat in Canary Islands
I'm looking for some DZR Hose Tails with a 90° bend, 1½" BSP and ¾" BSP.
Any suggestions?
Any suggestions?
ASAP http://www.asap-supplies.com/ certainly do 3/4 not sure about 1 1/2
Any suggestions?
...You can always make up the larger fitting with an elbow and straight hose tail?
http://www.asap-supplies.com/search/dzr+hose+tail for the smaller ones
That's what I have at the moment, and why I want to replace them.
Nigel, you say that as though it was self-explanatory, but what is the problem with separate elbows and hose-tails?
Bulky, plus an additional point of failure.
Probably not, but that is what is there now. I will investigate the possibility of using 135° (or even straight) hose connectors where possible, but I figure that at least some of the valves will need 90° bends.Is a 90 degree bend in a toilet outlet a good idea? ...
Is a 90 degree bend in a toilet outlet a good idea? It seems a better idea to keep the flow as smooth as possible. Although my Blakes 1.5 inch seacock (on which the flow inside the valve is not perfectly smooth) has never blocked I have noticed that carbonate accumulations seem to grow at the sharpest point of the bend, a good deal less than 90 degrees.
Any suggestions?
Anyone?... there was a recent thread that mentioned plastic hose fittings, can't find it.
Anyone?
