ash2020
My Hunter Medina has a lifting keel, weighing in at 300lb. At the moment it has a steel wire and winch for lifting. However, when the keel is down the bottom pulley and shackle are in the water leading to the wire being quite corroded. I could disconnect the shackle each time I lower the keel but as it's underwater it's a bit fiddly. If I were to replace the wire with maybe 8mm Dyneema, would it mind being submerged all the time? Does it deteriorate? And would an eye splice be strong enough?
