onenyala
I have 2 Volvo MD1B engines - one in the boat another spare each with dynastarters.
There is a significant difference in the circumferences of the sheaves on the two dynastarters which of course results in a significant difference in the rate of rotation of the amatures which are driven off the flywheel.
The circumference of the flywheel is 119 cms
The circumference of the smaller dynastarter sheave is 16cms and the larger 24cms.
At the working rpm of the engine - 2400 the rotation of the dynastarter armatures is 18,200 for the smaller sheave and 12100 rpm for the larger.
Both dynastarters are identical.
Can an electrically knowledgeable person tell me the pros & cons of the difference in rotation speeds and perhaps the correct sized sheave.
Both dynastarters seem to work OK both on starting and charging even though one rotates at 50% more rpm than the other.
