westerlylad
Active Member
Morning all. Any chance that I'll be able to re-use the existing gaskets if I remove manifold?
Many thanks Jonathan. I think I'll keep my fingers crossed that mine are okay when I take the manifold off. If not, I'll have a look for some gasket material. On another subject, I've just been looking at my exhaust bend and there is a fine split forming at the lower weld (the underside of the bend). The rest of the elbow appears okay and it is a sold lump of metal with no rust. Have you any thoughts about the possibility of a successful repair, either a weld or some epoxy? (Can you sense I'm running this boat on a limited budget?)I have re-used ours without issue but I have damaged them and I have bought a sheet of the appropriate gasket 'material' (A4 sheet) and I have cut my own.
Jonathan
Colin.
Thanks again for your reply Jonathan. I think I'll bite the bullet and just order a new elbow. The thing I cant understand is what causes this type of split in a substantial (and expensive) metal part. I don't see any signs of major corrosion either inside or outside, just the fine split forming along the underside seam. Mine was leaking unfortunately and will presumably get worse from here on. I understand the there is a stainless steel alternative for this part, so I'll have a look at that option too. Cheers. C.
