Sneaky Pete
I am about to fit a split charging system into my boat. The alternator output is 55amps the Durite split charger is rated at 140amps. The circuit requires a fuse either side of the split charge unit. Question is this would 10mm² cable rated at 110amps be alright and what fuse rating should be used either side of the terminals for this circuit it is my intention to use two midi fuse and holder?
