Mikedefieslife
I cannot think of a tiller that does not lift - If corrosion is an issue I'd be concerned Duralac, whether green (never seen it) or yellow would soon wear off.
This may be a case for constant remedial action and the only tube of Duralac not to last longer than the yacht.
Jonathan
It's a tiller arm. This is something that goes on a rudder stock a bit like a quadrant. Quadrants don't lift. Tiller arms don't lift. Quadrants tend only to be found on boats with cable steering and particularly monos. Tiller arms are found on boats with only hydraulic steering and frequently used on catamarans.
The tiller arm clamps onto the rudder stock with two M10 bolts then in lieu of a key uses grub screws. The tolerances in the 1/10 of mm range so there shouldn't be any movement.
Yes i've used Duralac before. Still have the stains on various items. The liquid I can think of that makes more mess is Sikaflex. Hate that stuff.
