Duck punt build - days 3 and four
going to start simple
Not for me it aint. One halyard and a captive downhaul. Nothing to lose. Fewer loose ends and only one adjustment ........ on the halyard.
I am going to start with the rig as simp as possible and then add the tweaks later
first coat of paint in the morning
second coat thursday
ready for christmas day launch if I can get a rig sorted
for some reason my wife seems keener of covering the sofa than making a sail
but with any luck the oppi rig will turn up soon
D
second tommorrow
D
Oppi rig? How lazy is that?
3 bits of wood, a few bits of string and you could have a proper rig.
Where is your sense of tradition?
I agree
but my guess is that the oppi rig will be more efficient when going to windward
although I might be wrong
my plan is to start with the oppy rig - if it gets here- and then apply pressure for a bit of sewing machine input
Dylan
Dylan
Efficient? What do you care? The quicker you get there the less time to enjoy on the water.
If you really want to go to windward cleat off the mainsheet and paddle on the leeward side.
I am sure....
I am sure you are correct
but there are times when you want to fetch around a corner
we shall see
mast made tonight - rounding off a bit of square timber
Dylan
Keep it easy...
I'd argue that it's worth sticking with what works. The Duck Punts were designed around an Oppi rig, and they clearly work well.
Change the rig, and you don't really have a Duck Punt, but something a little different and that might prevent you racing, if you wanted to, and making up a sail and rig is just so much work. That's not to say there aren't some good things about the balanced lug I think you're considering - including nice, easy gybing and good performance, if the sail's a good size and cut well.
But as there are lots of good Oppie sails and spars around that have been cast off by Optimist racers, that's what I try first.
Gav
Transport appeal
I'm trying to get a rig delivered to Dylan, but couriers either want £140 or won't accept long parcels at present.
If anyone is travelling from Essex to Dylan's area and could transport 2.5m x 100mm dia. could they help please?
Dan
