dylanwinter
snaps
it is the running rigging I want to see
how the ropes go where the spars meet
Dylan
Sail direct from Jeckells in Wroxham (Hoveton to be pedantic).
Dimensions: will have to unfurl again and measure, but the boat is 23' long and the mast I think 12' so that should give you some idea.
Mast is tubular sectional aluminium - from what, I know not because it came with my other Gun Punt - but I imagine not too difficult to find something similar on eBay.
Spars I made: Doug Fir from deck planking offcuts from my bigger project. Easy to make; 1.5" diameter (two bits 1.5" by 0.75" glued [epoxy] together). From raw to round in a day (if you remove the time for the glue to go off). I have some offcuts still if you want them...
If you want close ups, give me a list of which areas and I will try and get round to setting it up again. The rig is so, so simple to set up; I even have two strops on the boom to allow me to have a tall rig (so my wife can accompany me without decapitation) or a lower one for single handed or more blustery conditions.
The bit I'm most pleased with - believe it or not - is the attachement of the leeboard blades; captive cotter pins that belong on the back of a Land Rover tailgate, they self lock and tighten and can never get lost!!
The general concept was that everything must be able to breakdown and be stored within the confines of the cockpit or under the decks and still alllow 2 adults to lie down with their heads below the coaming. The rudder and treadle assembly is in 6 parts if I remember correctly but just takes 90 seconds to deploy
Dylan
