machineage
New Member
Hello all
I just wanted to pose a question about the above...
Proposed system:
Dual Batteries - one start - one house
BEP VSR or VSS
On-board Charger (one or two)
Now when underway I understand that when the start battery voltage reaches a preset level the VSR will activate and parallel the batteries.
What if the house battery is quite depleted - will the charge from the start battery dissipate into the house battery causing a lack of charge in both?
Also - when I am at shore and connect my battery charger - how would this work in the above system? Again if it's a dual sensing VSR then I understand when one battery reaches a preset level the VSR will activate with possibly a similar situation to above?
How would a battery charger deal with this situation - don't they detect and charge batteries individually in the case of a dual bank charger?
I note that CTEK supply a larger charger (M300) for the house batteries and a smaller charger for the start as a package. How would I wire these up with the VSR or VSS?
Thanks!
Proposed system:
BEP VSR or VSS
Thanks!
