richlear
Hi all,
I have a 2015 Beneteau 31 with an NMEA2000 B&G instrument setup using a Zeus2 MFD installed from new.
Airmar Triducer IDST-N2000
Part number 44-127-3-01
Rev 13
FW 1.022
Up until very recently I was able to read depth but it has suddenly stopped. Not zero or erroneous data, just no depth data.
1 - The DST200 is being recognised on the N2K network. I can see the serial number and data coming from the instrument but it is only boat speed.
2 - I checked the DEPTH data source on the MFD and is it correctly selected to DST200
3 - I pulled the transducer. Flicking the wheel changes the boat speed on the MFD and I can hear the sounder ticking. There is no growth on the transducer.
4 - Reset the devices and data sources on the MFD, restarted.
Still no depth.
I have concluded that the power/physical data connection is OK because I see other data. The MFD recognises the instrument as it reads serial, SW versions and I see live speed data. It is almost as if the DST200 has configured itself to only export boat speed and not depth data.
I do not see any configuration options through the MFD other than a depth offset.
Is there a way to configure the DST200 or at least check how it is configured?
Any other ideas?
Thanks in advance
Rich
Rev 13
FW 1.022
Still no depth.
Any other ideas?
Thanks in advance
Rich
