ianj99
Navicom RT-650
The has AIS baud rates of 4800 or 38400 - selectable in the AIS setup menu.
However nowhere is it stated whether the same baud rate is applied to both input and output, so possibly the output is the standard 38400 and its just the input baud rate that is selectable.
I also found a bug in Belfield's Chart Plotter - it kept coming up with an 'exception' every few seconds which seemed to be if AIS data was sent on the same com port as GPS & instrument data rather than on a separate port.
Belfield's 'fix' was to disable the warning message after it had popped up 5 times. I was also concerned that it kept failing to display some vessels on the chart even though both Polarview and the RT650 showed them to be present. One was the nearby Cal Mac ferry - less than 3miles away.
