Drying out and repairing frames
Simon1974
18 Oct 2025
I’ve recently acquired Captain Moonlight which is a Paul Whiting design from 1976. The boat has been in a garden for a number of years and there was a cow churns worth of water extracted. The boat feels wet and needs drying out. The mast step frame looks like it is rotten but I need to really dry the boat out before I can work out if CM is salvageable.
Any hints on drying out and repairers in the South West, Sherborne way.
I’d like to restore the boat but I need to be sensible
D7A17AB5-760B-4B55-8211-1BD7B3E62463.jpegFirst thing I would suggest is to get the paint stripped off to expose the bare wood.
That’s what I’m doing, quite a lot of the cockpit wood needs paint removing and in places there is reinforcing GRP added. Unfortunately the GRP didn’t bond to the wood in quite a few places and has created pockets which trapped water.
I have a dehumidifier going 24-7 for a week and it’s taking out quite a lot of moisture. I’m more hopeful after a weekend of stripping paint and allowing the wood to start drying out but I’m also quite naive…
I don't know how effective a dehumidifier will be.
I'd favour erecting some kind of open-ended tent over the boat (to keep the rain off), opening up the hatches and windows and letting the wind blow through.
The boat is inside now. With the hatch sealed up I think the dehumidifier has taken out 6-8 litres so far. I do agree that some forced air through the cabin would be helpful
I didn't realise she was inside. Makes the job pleasanter.
If you use the dehumidifier you have to keep everything sealed up otherwise you'll be dehumidifying the shed as well.
If you rely on ventilation, everything needs opening up. Maybe get some fans to keep the air moving.
Yep, all sealed up, even the speakers. I’ll take a measurement of how has been removed on Friday as that’ll be 12 days worth of constant running.
Being inside for only a short amount of time has made a big difference but I think it needs to be back to wood in the cockpit so I can assess the job ahead. The hull has bubbles which I assume is moisture so that will need to be sanded back to base paint layer as well. Not a quick fix and a feasibility assessment is needed.
Will probably look to get a light survey to see if this a go-no-go
It looks like she is a grp hull? with wooden floors etc. The mast step looks like its laminated.
I would get as much paint off as you can to speed drying out. Im not sure if dehumidifier will be any faster tbh.
Think i would have it on if its cold & damp & open up with fan on when its warm.
Summers coming so she will dry out then!
The hull has a GRP top lip where the cockpit has been reinforced but I don’t think the rest of the hull is covered.
I’m going to take the steel mast step off this weekend to allow the air to get to it and I agree that once it warms up some air flow will probably do a better job than a dehumidifier.
Most important is removing the damages layers and let the air do its job.
If she is cold moulded any paint needs to be stripped off the inside or anywhere wet or it will never dry out. A moisture meter will be very useful, i have an extech one & its excellent plus cheap off amazon!
A lot will depend on what glue she is laminated with, hopefully epoxy, if its UF glue i wouldnt bother as its lifespan is 30 to 40 years after which it starts to break down.
