Allan
Not good news!
I now have a lot more information.
The joint, shaft and prop are all OK. The probem appears to be in the gearbox.
The gearbox is a Hurth HBW 150 made by ZF (model ZF15M). I have learnt that losing drive in one direction is normally caused by wear to the clutch plates, which then need replacing. The only thing that is not consistent with this is that normally the debris from this wear contaminates the fluid but my fluid, on the dipstick, appears to be clean.
I'll be on the boat tomorrow to drain the oil and see if there is contamination settled out in the bottom.
If anyone has any experience of this type of gearbox or problem, I would be interested to hear from them.
Allan
Allan
